• Strata Miniatures
Strata Miniatures
Strata Miniatures
Quality Square Edge Dice x 10 - Solid Orange - Custom Six Side
Store/Custom Dice, Trays & Gaming Accessories/Square Edge dice - Custom 6 Side
£15.00
Artwork
Add Files...
Add More Files...
In stock: 2 available
Simply upload your image to us and we will make your custom dice a reality. If we have any issues with your design we will get back in touch with you.
IMPORTANT: Unless otherwise stated, your logo colour will be matched to the pip colour.
What is the best type of image file to upload for a custom item?
We should be able to use any EPS, jpeg, PNG or CDR file. If you send another file type, your order may be delayed and we will ask for another file. Please ensure they are a black/white image where possible. The black areas will the parts of the image that will be engraved (and on dice, those areas would be paint filled). If your image is too detailed for us to engrave, we will let you know and ask for a more suitable image. Photographs are not suitable to engrave.
Please note that dice can only be filled in one colour.
Dice are a choking hazard and should not be given to children.
THIS IS NOT A TOY.
© Strata Miniatures Report abuse
